Sponsored by: CARiD
Dead Car
Old Dec 15, 2008 | 06:37 PM
SShag's Avatar
Default Dead Car
This morning i went to warm up my 98 SS and when i turned the key the lights on the dash came on for a quick second then everything went dead, i couldnt start the car, unlock the trunck, lock the doors or nothing. Its not a dead battery cuz there is no clicking when i try to crank the motor. Now, when i got home from work a few hours later, it fired right with no problems and everything works. What the hell, i dont wanna be stuck somewhere and have the same problem any suggestions??? thanks
Old Dec 15, 2008 | 08:00 PM
BlueMagicSS's Avatar
I had the exact same problem.... check the battery cables. I removed them and put them back on made sure they were tight... and haven't had the problem since...
Old Dec 16, 2008 | 07:15 PM
xRelapse13's Avatar
i had the same problem, when it happens pop your hood and kinda play wiht the battery ground cable and everything will usually go back on. mine would do the same thing, it would click and hten everything would shut off, i'd go twitch the ground cable and you would hear everything go on. When i have a chance im gonna redo them but haven't had a chance.
Old Dec 17, 2008 | 08:32 AM
bboyferal's Avatar
When the lights turned off, did the security light stay in the dash?
Old Dec 17, 2008 | 11:10 AM
bjamick's Avatar
Sounds like your ignition switch to me. I can almost guarantee it . Have had them go bad in 2 different cars one Fbody and one toyota.
