Sponsored by: CARiD
Turn signals
Old Dec 25, 2008 | 05:21 PM
DBurgLT1's Avatar
Default Turn signals
My passenger side turn signals work fine but the Drivers side ones don't. When I turn on the drivers side turn signal the bulbs light up but they do not blink. The same is for the light on the dash.
Old Dec 25, 2008 | 09:09 PM
xephona's Avatar
They light up solid when one of the bulbs is burned out on that side (or possibly the wiring is screwed up on that side)
Old Dec 25, 2008 | 11:27 PM
wrencher's Avatar
wrencher
Put a flasher in it first, likely the problem.
Old Dec 26, 2008 | 02:02 AM
amich187's Avatar
I had the same problem with mine. It turned out to be the turn signal bulb socket itself. You can find them on gmpartdirect.com
Costs about $40 but that was definitely the issue for me. Hope this helps...
Old Jan 2, 2009 | 11:02 PM
95TAJade's Avatar
mine does the same thing from time to time. I just pull the bulb/socket out from the turn signal housing and brush off a layer of dirt and road grime that made its way up in there and it's good to go after that!!
