Sponsored by: CARiD
Dumb question
Old Dec 27, 2008 | 03:00 PM
jc99ls1ss's Avatar
Default Dumb question
I have a squeak when the car is running. I believe it is coming from the bottom passenger side idler pully. What is the thing that the second small belt is running? Can I just take the belt off? It is a 99 Camaro SS M6.
Old Dec 27, 2008 | 03:11 PM
mkwldss's Avatar
It's your A/C compressor.
Old Dec 27, 2008 | 03:20 PM
question's Avatar
I have the same squeak, and my compressor also needs a recharge. Do you think there is something in common, will the squeak go away with a recharge? I know the stuff has oil in it to help lubricate inside the compressor.
Old Dec 27, 2008 | 03:42 PM
mkwldss's Avatar
I'd check out the belt to make sure it doesnt have a bunch of cracks on the ribbed side of the belt. Then check out the idler/tensioner pulley. That bearing can become worn out, especially on older cars or high mileage ones. Take the belt off and see if it goes away?
Old Dec 27, 2008 | 03:49 PM
LS6427's Avatar
Yeah, take the main serpentine belt off, then take the compressor belt off. Use a ratchet to attach to the tensioner pulley below and that will release the tension so you can easily take the belt off the compressor wheel.
