Sponsored by: CARiD
***Weird Miss....PLEASE HELP!***
Old Jan 5, 2009 | 10:56 PM
LS6427's Avatar
Originally Posted by 04_turboed_neon
**I also heard about the terminal thing, a buddy told me about it the other night. I usually jsut unplug the negative terminal and turn the ket over a few times.**
Try it this time by taking just the pos wire off and tapping it against the pos battery terminal port.
Old Jan 6, 2009 | 08:58 AM
04_turboed_neon's Avatar
After resetting the PCM it still misses alittle on every cylinder, its very random misfire. This was kinda wierd, the Map sensor voltage was at or above 2v at idle. Should it be there? Also, when i pulled the map sensor, there was a part of the rubber grommet that had a little tear, at the bottom, but had actually cut through the whole rubber grommet. Could taht be it? Replace grommet, or whole sensor?
I do have boltons, and cam, FYI.
Devin
Old Jan 6, 2009 | 11:48 AM
Well its not the MAP sensor. I replaced it, reset comp, and still miss firing everywhere. WTF!!!
Devin
Old Jan 6, 2009 | 11:55 AM
1987firechicken's Avatar
Out of curiosity what kind of plugs did you use when you changed them? What heat range are they?
Old Jan 6, 2009 | 12:29 PM
NGks at stock heat range. Tr5's
Devin
Old Jan 6, 2009 | 12:45 PM
LS6427's Avatar
Devin
Damn!!!!! Maybe pull them to make sure none are cracked. Did you make sure the gaps were correct and not totally messed up?
Old Jan 6, 2009 | 12:52 PM
I gapped them all at factory specs(60) before installing them, and none are damaged, i've already pulled them out and inspected them.
Devin
Old Jan 6, 2009 | 12:54 PM
LS6427's Avatar
Devin
Take the radiator cap off, drive your car away and drive a new car under it, replace cap.
Old Jan 6, 2009 | 12:55 PM
LS6427's Avatar
Only other thing is an electrical short somewhere in the ignition harness. Maybe take it all the way off the car and check it out.
Old Jan 6, 2009 | 02:13 PM
Trust me, if that was an option, she'd be gone right now. lol damn random misfires.
Aight, i'll see what i can do.
Devin
Old Jan 7, 2009 | 09:42 AM
Could it might be a Cam sensor, or crank sensor? I know most people say that when a crank sensor fails it usually wont crank, but could it be failing?
Devin
Old Jan 7, 2009 | 09:51 AM
  #32
LS6427's Avatar
Devin
THe Crank Shaft Position sensor can do exactly that...hard starts, stalls suddenly, and bucks and runs like hell.
And yes, the CSP sensor can fail over time, while its failing, sometimes it works great and sometimes you get those symptoms I listed above.
You can change it out in 5 minutes after you lift the car up on ramps or a lift. Drop the starter and its right there.
You can get one at Advance Auto or PepBoys to try, if it doesn't help you can clean it up and bring it back for a refund.
Also, if it is a bad CSP sensor, it WILL NOT neccassarily give you an SES light and a cheap scanner like they have at Advance or PepBoys might not show the code. When mine went, it took the expensive OBDII scanner that the dealerships use to show it.
Old Jan 7, 2009 | 08:26 PM
  #33
welp its not the crank sensor. IDk anymore, im gonna take it my tuner and let him mess with it.
Devin
Old Jan 7, 2009 | 08:45 PM
  #34
billymz28's Avatar
just because the plugs are new it dont mean they cant be cracked. I work at a part store and the plugs are thrown around in baskets and in shiiping when stocking.it happens more than you might think. I also had a friend who had the same problem with a misfire and it just randomly went away still dont know why.
Old Jan 7, 2009 | 09:08 PM
  #35
Sharpe's Avatar
You meant the front O2's, right? The rear ones mean nothing. The front ones can cause the car to miss, though mine showed no misses when I switched mine from right to left bank on accident. I went out and got new Bosch 13111's so I wouldn't have to run the extensions, and put them on the right side (duh). Fixed my random misses.
Old Jan 9, 2009 | 10:15 PM
  #36
sic2001's Avatar
Did you delete the EGR (if you have it)and Air system,unplug pump get rid of all those vaccume lines behind the intake? I had the same problem and it went away only when I did that.
Old Jan 9, 2009 | 11:11 PM
  #37
CayenneRedV6's Avatar
I had a miss at high rpm's I couldn't track down after I installed my headers. I spent hours trying to find what was causing it. It turned out to be the gap on the plugs. I had gaped them to the factory .60 but after taking them out and re-gaping them to .35 NO miss fire. Try re-gaping them to .35 and see if that helps.
