Sponsored by: CARiD
VATS question, help please
Old Jan 5, 2009 | 06:44 PM
paulc87's Avatar
Default VATS question, help please
I have already done the VATS bypass and had it disabled in the PCM. But the VATS system still keeps me from starting the car intermittently, usually several times in a row. Sometimes the light will flash and I will have to move the steering column up and down while turning the key for it to start. I'm 99% sure that it is the ignition lock cylinder, but I just wanted to confirm this before I take it to the shop. Any suggestions appreciated.
Thanks
Old Jan 5, 2009 | 06:59 PM
2001NBMZ28's Avatar
If the resistor you put in the connector to bypass it is secure, and correct value, that should do it and not flash the security light.
Old Jan 5, 2009 | 07:06 PM
paulc87's Avatar
Yes but I think one of the wires in the lock cylinder is making intermittent contact
Old Jan 5, 2009 | 10:49 PM
paulc87's Avatar
Also I forgot to mention that the Security light comes on while im driving for approximately 5 minutes or so
Old Jan 6, 2009 | 01:16 AM
beezer1519's Avatar
when you have a pretty strong feeling on what the problem is go with it because it most likely is
