Sponsored by: CARiD
Air Bag Light....
Old Jan 16, 2009 | 02:05 PM
gc302047's Avatar
Default Air Bag Light....
after changing my oil pan gasket a little while ago i had to drop the k member and im thinking maybe a connection went lose or something. i dont know were the air bag connections are? right after putting everything back on it came on and will not go off. can somebody help?
Old Jan 16, 2009 | 08:59 PM
gc302047's Avatar
well...?
Old Jan 16, 2009 | 09:26 PM
70hemicuda's Avatar
Did u try disconnecting the battery and pushing the gas pedal a couple times? I dont really know how to help, but that made my Low Oil light go away. Although thats probably a different control module. Worth a try??
Old Jan 19, 2009 | 10:48 PM
gc302047's Avatar
i have never heard of that method. probably will not work but i guess i could try haha
Old Jan 20, 2009 | 09:01 AM
406malibu's Avatar
did you take the console out? one of the air bag modules is under there I believe (the little metal box)
Old Jan 20, 2009 | 10:10 AM
BobDoLe's Avatar
there's a yellow wire under the dash (panel under steering wheel) that runs to that box, but i don't see how dropping a k-member would affect it.
i'd say you need to re-check all of your ground connections and fuses.
Old Jan 20, 2009 | 04:02 PM
Mr LSX's Avatar
Look for yellow plugs and wires. That is the airbag stuff.
Old Jan 20, 2009 | 06:47 PM
gc302047's Avatar
do you have any idea were that stuff is?
Old Jan 20, 2009 | 07:49 PM
sway99bird's Avatar
I agree with bobdole with that one
Old Jan 20, 2009 | 08:08 PM
dave70's Avatar
some of the wires for the airbag are under the dash on the pass. side.
Old Jan 20, 2009 | 10:29 PM
LS1axle's Avatar
Did u check the air bag fuse?
Old Jan 20, 2009 | 11:44 PM
gc302047's Avatar
checked the fuse wasent bad going to take it to the dealer i dont want to deal with it hope i dont get a huge bill.
