coil harness check engine light
Just got done doing the heads on my car and we had some problems with it running after putting it back together. Basically I had the coil harnesses flipped to it was running on about 4 cylinders. After I switched them back to what I'm pretty sure is right, meaning it seems to run fine, I got a check engine light that basically says the coil harness fault. Any ideas?
thanks,
pete
