Sponsored by: CARiD
defroster
Old Jan 22, 2009 | 08:57 PM
steverr's Avatar
Default defroster
When I put the defroster on there is a hissing noise coming from the dashboard, it only comes on if just the defroster is on, if i put it on the mode where heat goes to feet and defroster it doesnt do it. If i use regular heat it also doesnt do it..any one know why it would make a hissing noise
Old Jan 22, 2009 | 09:01 PM
WhiteFormula98's Avatar
Did you check to see if there is a snake in the vicinity?
Old Jan 22, 2009 | 09:20 PM
SparkyJJO's Avatar
Could be a vacuum leak, I'm pretty sure the system that directs the airflow is controlled by vacuum lines and valves.
Old Jan 22, 2009 | 10:33 PM
sway99bird's Avatar
It's a snake
Old Jan 22, 2009 | 10:38 PM
ghardester's Avatar
The control for the heat/air/defrost is controlled by vacuum. There is a multi hose fitting behind the dial. Pop off the trim and remove a couple screws and pull out the control. You may have a leak behind the control.
Old Jan 25, 2009 | 06:29 AM
steverr's Avatar
but how come I only hear it when the defroster is on, and not the heat?
