Sponsored by: CARiD
Can't open driver door from outside.
Old Jan 25, 2009 | 02:29 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
Default Can't open driver door from outside.
Yes, I did a search. All I was able to find was the driver's door not being able to be opened at all because of the locking mechanism failing. But, that's not the case. I can't open the driver's door only from the outside. And ideas?
Old Jan 25, 2009 | 02:44 PM
wrencher's Avatar
wrencher
Either the the handle broke, or the rod came off or the latch is stuck.
Need to take the door panel off to determine which.
Old Jan 25, 2009 | 02:45 PM
the_merv's Avatar
Veteran: Air Force
Exactly. Pull the Door Panel and check the Linkage.
Old Jan 25, 2009 | 05:11 PM
One of the plastic brackets that holds the rod in place for the outside door handle broke. Got it fixed now. Thanks for the help guys.
