Sponsored by: CARiD
pcv valve on a 1998 t/a
Old Jan 26, 2009 | 07:11 PM
slayerized6's Avatar
Default pcv valve on a 1998 t/a
where is the pcv located on a 1998 t/a?
Old Jan 26, 2009 | 08:31 PM
Formula413's Avatar
Just behind the throttle body on the passenger side. There is a rubber boot around it, look for a line just behind the TB running to the back of the intake manifold.
Old Jan 26, 2009 | 10:17 PM
Crimsonnaire's Avatar
It should be the rubber hose that shows some metal. That's the valve. To access it, you just hold one side with the valve and slowly rotate the other side out.
Old Jan 28, 2009 | 01:04 AM
camaroguy26's Avatar
it's that hose they're talking about. It actually has a clip taped to it that clips to the valve cover about in the middle of the cover front/back
