Sponsored by: CARiD
odd whining coming from engine
Old Feb 3, 2009 | 09:21 AM
tuffluck's Avatar
Default odd whining coming from engine
it won't do it at idle, in fact only when i'm rolling. when i roll in reverse it's the worse, when i go forward it does it a little but mostly only when i turn. i suspect something in the wheel area or the PS pump, but have no way to check it because i can't isolate the problem unless someone rides on my engine while i'm driving, lol. anybody have any clue? it's just a high-pitched hissing/whining noise. hard to describe any better really...
Old Feb 3, 2009 | 09:28 AM
hj99Z's Avatar
Still have your stock 10 bolt in there?
Old Feb 3, 2009 | 11:10 AM
CoastieWS6's Avatar
My car made a whine. Like a SC, so I greased the tenson pullies. That wasn't the problem, so I checked the PS pump and it was low. Filled it up and whine went away
Old Feb 3, 2009 | 12:21 PM
nemss1's Avatar
sounds like the PS pump. check the fluid level of the pump
Old Feb 5, 2009 | 02:07 PM
SOMbitch's Avatar
My PS fluid was filthy at 60k and made a slight whine when cold. I sucked the PS resevoir out with a turkey baster and put synthetic fluid back in and no noise a year later.
Old Feb 5, 2009 | 03:14 PM
nemss1's Avatar
when mine took a crap, i just ripped my PS off and went to manual steering haha
Old Feb 5, 2009 | 07:30 PM
BobDoLe's Avatar
could be the rear end. fuel pumps whine too.
Old Feb 6, 2009 | 09:47 AM
tuffluck's Avatar
it is definitely coming from the front of the car, like right near the wheel on the driver's side. you can rule out fuel pump or rear end.
i checked the PS fluid and it was quite low. filled it up and the noise is still there. i think it might be my brakes maybe? i think they could be dragging on the rotor? i dunno...i only hear it when the car moves and especially when the tires make more movement than not. and oddly enough when i go in reverse and tap the brakes it is the worst. i don't know but it sounds suspension related. anyone have any ideas?
Old Feb 6, 2009 | 11:47 AM
nemss1's Avatar
check your rotors. they may need turned
Old Feb 6, 2009 | 11:55 AM
SOMbitch's Avatar
Tuff guy
I like my creature comforts to much!!!
Old Feb 6, 2009 | 12:01 PM
nemss1's Avatar
Tuff guy
more run when it feels like your driving a big go-kart IMO
Old Feb 6, 2009 | 02:46 PM
BobDoLe's Avatar
if you're sitting there at idle and turning the wheel left-right and its not making the sound, i would think the power steering would be fine. otherwise, it sounds like the pumps going out.
Old Feb 6, 2009 | 07:04 PM
nemss1's Avatar
maybe the seals are worn out inside the pump
Old Feb 7, 2009 | 04:52 PM
proporio's Avatar
When I read the title of this thread,
I was wondering what the hell my wife was doing in your engine bay!
j/k
Old Feb 7, 2009 | 06:30 PM
nemss1's Avatar
j/k
Old Feb 9, 2009 | 09:17 AM
tuffluck's Avatar
haha, nice. well my friends listened to the noise and it's coming from the rear wheel on the driver's side, so it's got to be the brakes i bet. i haven't changed them ever, and have no idea if the owner before me ever changed them either. my car has 70k on it and i bought it with about 35k, so yeah, i'd say they are due...
Old Feb 9, 2009 | 12:49 PM
nemss1's Avatar
could be worn brakes or the rotors need turned
Old Feb 13, 2009 | 08:50 AM
tuffluck's Avatar
it was definitely the rear brakes. i changed them last night and the noise went away immediately.
