Sponsored by: CARiD
HELP:powersteering problems
Old Feb 5, 2009 | 04:30 PM
35le's Avatar
Default HELP:powersteering problems
My cars powersteering has been giving me problems, the car is very hard to steer at idle and low speed and makes noise, but when the car is cold and i first start driving it is fine but as it gets hotter the harder it steers. Also i thought there was coolant in my powersteering so I by-passed my powersteering cooler and took out the old fluid with a little pump. Any help would be appreciated thanks.....
Old Feb 5, 2009 | 05:06 PM
nemss1's Avatar
no the PS fluid is red also and looks like coolant. may have a leak or the pump is shot
Old Feb 5, 2009 | 05:26 PM
35le's Avatar
Why would it work fine then get worse as the car gets hot?..
Old Feb 5, 2009 | 05:40 PM
GrimReaper's Avatar
does it make any noises? when the car is running and you open the ps resivour is the fluid airrated?
Old Feb 5, 2009 | 05:58 PM
35le's Avatar
Yea it makes that powersteering wine, like when they are low on fluid, but its not. Kinda like its struggling..
Old Feb 5, 2009 | 06:03 PM
35le's Avatar
By airrated do you mean bubbles, if so no there are none...
Old Feb 5, 2009 | 07:33 PM
GrimReaper's Avatar
yes i did mean bubbles. have you tugged on the power steering pulley? I work at a GM dealership and sometimes the shaft on the pump will crack and or break. it will look fine till u pull on it. Also you dont have any leaks? how about from the pinion seal of the steering gear? also you can poke a pinhole in the inner tie rod boots and see if there is a fluid build up in there. it will drip out at a descent rate if so. thats a quick check for the steering gear seals.
