Sponsored by: CARiD
Headlight qeustion
Old Feb 7, 2009 | 06:56 PM
97ta383's Avatar
Default Headlight qeustion
So today i noticed my headelight was out on my 2002 trans am i was like ok and put a new light in it it still didnt work and neither does the hi beam its on the drivers side anyone ever have this problem before or have any suggestions on were to start to fix it? thanks
Old Feb 7, 2009 | 07:09 PM
nemss1's Avatar
could be fuses, switch or DRL module. thinking on the top of my head
Old Feb 7, 2009 | 07:25 PM
BoostJunkieXL's Avatar
Does the headlight motor work? If I'm not mistaking if the motor has a short then the lights may not work. I was having problems with mine like that and the motor was the culprit.
Old Feb 7, 2009 | 07:48 PM
97ta383's Avatar
Im pretty sure the motor is working fine it goes up and down with no problem yea i do need to check the fuses and what and where is the DRL module
Old Feb 7, 2009 | 08:10 PM
nemss1's Avatar
module behind the dash mounted to the dash brace. about the size of a pack of cigarettes and has a blue connector and black connector running to it
Old Feb 7, 2009 | 08:11 PM
97ta383's Avatar
oh ok ill have to check that too thanks for the help
Old Feb 7, 2009 | 08:29 PM
nemss1's Avatar
no problem man
