Sponsored by: CARiD
Car Tries To Die When Started
Old Feb 14, 2009 | 10:32 AM
badazz99ta's Avatar
Default Car Tries To Die When Started
of folks, when i first got the car the ac didnt work. and it started fine. when i got the ac fixed it wouldnt stay started, you kept having to give it gas and after a few minutes it would be fine. then i found out my battery was bad as well as my alternator. so i had my alternator rebuilt and a new battery. that actually helped a lot. but would still try to day if you started the car with the ac/heat on. so i just turned it off and started it and all was fine. recently though, when i start the car with the ac/heat off it will die. so i have to give it a little gas for about 30 seconds and it is fine. it will do it everytime i start it, no matter how warmed up or how cold the car is. so, what the hell could this be. do i need to get it re-tuned. the car idles at about 1100-1200, which is too high in my opinion. thanks. Dan
Old Feb 14, 2009 | 02:16 PM
blade2222's Avatar
clean the throttle body and ICM, see if this works if not you might have a vacuum leak.
Old Feb 14, 2009 | 02:23 PM
nemss1's Avatar
could be a vacuum leak or a faulty sensor
Old Feb 15, 2009 | 05:33 PM
badazz99ta's Avatar
i will clean the throttle body, but what is the icm?
Old Feb 15, 2009 | 06:39 PM
2001NBMZ28's Avatar
Maybe meant IAC?
Old Feb 15, 2009 | 07:07 PM
nemss1's Avatar
^^^ya try checking the IAC valve
