Upper & Lower Radiator Hose Failures
When I first got the car, one of the little caps at the bottom of the radiator was leaking, had that repaired, and the hose issue came after that.
I'm taking it to the mechanic tomorrow, anyways, but any ideas what might be causing the hoses to come off?
Thanks.
Thanks.
I can;t see how a screw type clamp can possibly come off if tightened enough. You should lose pressure through the radiator cap first.
This is a 98 TA, btw, so the gauge should be relatively accurate.
