Sponsored by: CARiD
A/C help
Old Feb 16, 2009 | 10:35 AM
NxLS1496's Avatar
Default A/C help
Car is an 01 z28 m6 with about 50k miles on it. Lately my A/C has not been working properly. When i turn the car on and it is idling/at stand still the a/c blows hot. However, as soon as i get up to about 50mph it blows pretty cold. Im hoping it just needs a little freon. anyone has an suggestions? thanks.
Old Feb 16, 2009 | 12:08 PM
LS6427's Avatar
Sounds like you might just need more refrigerant. When you sit still you have no airflow going through the condensor thats in front of the radiator. When you move you start to get that airflow and the heat from the condensor gets carried away.
Old Feb 16, 2009 | 10:16 PM
RE AND CHERYL's Avatar
Also check to see if the fan is running. If not fan is running when the A/C is on, the condensor will overheat in no time flat if there is no airflow through it (like when you are stationary).
Re'
Old Feb 19, 2009 | 11:41 AM
NxLS1496's Avatar
Re'
Fan is definitely running, condensor feels pretty cold, but no as cold as it should be. is there anyway to tell if im low on freon?
Old Feb 19, 2009 | 12:25 PM
2001NBMZ28's Avatar
If you want to check it yourself just pick up a recharge kit that includes a gauge. It'll only connect to the "low" side and you'll be able to read the static pressure, and then see if it's within limits when the compressor cycles on. The condenser is in front of the radiator, you want to be sure the outside fans are coming on - not to be confused the the blower motor fan inside the car near the evaporator.
