Sponsored by: CARiD
Car will not start...
Old Feb 17, 2009 | 09:45 PM
stang56k's Avatar
Default Car will not start...
ok, heres my first thread when I suspected the VATS to be acting up...
https://ls1tech.com/forums/general-m...on-system.html
Ive checked the ohms with the key in the ignition and it checks good, Well the battery was getting low from testing so I jump the car and it started. This is two times the car started while being jumped. After the jump we got the car to start 3 times without being jumped. But, then will not start. I had the battery checked at autozone last saturday and it checked good according to their test. The starter spins and sounds fine and I hear the fuel pump coming on and stays on for 5 secs after start attempt. We really leaning towards a neutral safety switch...Also, Is there anyway to check the VATS modual or BCM to see if those are not the problem?
Old Feb 18, 2009 | 04:53 AM
lovin myls1's Avatar
If the starter always spins it's not the neutral saferty-if that switch opens it will cause the starter to go dead.Do you get any security light?
