popping sound while turning
If it happens while turning, it could be tie-rod ends, or anything else in the rack.
If it happens while braking, it could be springs or LCAs.
I don't think it's a hub because it would be constant - all the time - if it was.
Given the above, do you want to live with the noise for now, or are you interested in preemptively repairing the issue? (Again the shop has some wisdom here. Preemptive fixes are very expensive for someone else to do - but if you do the work yourself, it could make better financial sense.)
