Sponsored by: CARiD
Screeching/squeaking sound during takeoff
Old Mar 1, 2009 | 12:55 PM
99Zeeeeeeeeee28's Avatar
Default Screeching/squeaking sound during takeoff
So everytime I start out going from a stop normally (i.e. feathered throttle) everything is fine and there is no noise. If I put a little more gas down than usual, I get this screeching/squeaking sound. At first I thought it was coming from the rear end but it's so hard to tell. It only does it when I put a little more into the throttle than feathering it but if I floor it, the noise isn't there. It also does it when the car shifts into second if I feather it from the start and put it a little farther down right before the shift. Please help with this one guys. I'm hoping its not the rear end because I would be really screwed right now if it was. Also, I never beat on the car - I get on it maybe once or twice a week and when I do, it's only from 25 or higher and I never go above 80.
Old Mar 1, 2009 | 01:24 PM
LS6427's Avatar
Put it in the air, you might have some worn out tranny mounts. Never heard of a rear-end squeaking, usually its a deep moaning sound and gets higher and lower with speed changes.
Old Mar 1, 2009 | 05:56 PM
Thanks for the replay I'll have to check that out. Hopefully its just something like that. How bad are those to replace?
