Sponsored by: CARiD
Oil Pressure Gauge
Old Mar 1, 2009 | 09:30 PM
8675309's Avatar
Default Oil Pressure Gauge
My oil pressure gauge on my car is going insane. I'm pretty sure that it's just broken because it's bottomed out. I don't think that it would have over 80 psi. If it could though what would be wrong with it? It's totally buried though. I'll try to get a picture of it.
Old Mar 1, 2009 | 10:44 PM
camarolover209's Avatar
its definetly or pressure gauge there usually like 35 bux at autozone or kragen
Old Mar 2, 2009 | 08:30 PM
8675309's Avatar
So i'm alright? I don't have to worry about my motor blowing its just the gauge?
Old Mar 3, 2009 | 09:19 AM
crossroads's Avatar
pd 30 for one at the local part store when i swapped to an LS6 intake, turns out my old one was about to fall off anyways but i broke it when i pulled the intake
Old Mar 3, 2009 | 07:00 PM
SOMbitch's Avatar
It is most likely the the oil pressure sending unit. Mounted on the block behind the intake driver side. Intake needs to come off to change it. Pretty common problem....
Old Mar 4, 2009 | 02:06 PM
TLUZLS1's Avatar
Did you pull the intake recently? Either way get a new one, it's technically called an "oil pressure switch" (i dont know why) but just pull the intake and it's sitting behind it. Hopefully it's just unplugged lol.
Old Mar 4, 2009 | 07:53 PM
SOMbitch's Avatar
You may want to spend a few bucks on a special plastic socket to help you put the new one in without breaking it. IIRC I got mine in the "Help" section at the "Zone" or "Advance".
