Sponsored by: CARiD
Engine oil light
Old Mar 5, 2009 | 01:08 PM
dondb's Avatar
Default Engine oil light
At start up, how long does it take for the oil pressure light to go off?
Mine stays on for about 2 minutes, is this normal? It stays on that long cold or hot start?
Old Mar 5, 2009 | 01:17 PM
2001NBMZ28's Avatar
Do you mean change oil or low oil?
Old Mar 5, 2009 | 01:59 PM
dondb's Avatar
Low oil.
Old Mar 5, 2009 | 02:14 PM
2001NBMZ28's Avatar
Low oil comes on when you're about 2 quarts low. After filling to proper level it'll go off by itself on the next ignition cycle after the PCM sees 194*? ECT. If the oil level is fine something is wrong with the sensor/wiring.
Old Mar 5, 2009 | 02:47 PM
wht01ws6ta's Avatar
Or it's possible the ECT isn't getting up to 194°. I know with a 160° stat I didn't see that kind of temp in the winter.
Old Mar 5, 2009 | 07:47 PM
dondb's Avatar
Must be the sensor then, oil is to the top and i have the original thermostat. I just wanted to know if that was normal. Thanks for your replys!
Old Mar 6, 2009 | 08:49 AM
2001NBMZ28's Avatar
This is for a 2K but might help: www.gearchatter.com/viewtopic8944.php
