Sponsored by: CARiD
I disconnected the battery and...
Old Mar 12, 2009 | 11:38 PM
csucguy18's Avatar
Default I disconnected the battery and...
when i re-connected it again now the 'BRAKE' light stays on permanently and the interior lights dome lights don't work! I also hear this intermittent *click* coming from somewhere behind the passenger glove box. WTF???
Old Mar 13, 2009 | 01:50 AM
Z28LS1camaroguy's Avatar
check fuses, did you disconnect the positive or negative?? if you disconnected the positive then reconnected you could have blown fuses.
Old Mar 15, 2009 | 06:56 AM
Nova5's Avatar
clicks are normally relays closing or opening.
If you disconnect/connect the battery in the wrong order you can cause sparks at the battery that could blow fuses as mentioned above.
