Sponsored by: CARiD
squeek when turning on heat?
Old Mar 13, 2009 | 09:41 PM
NeedaV8foundation's Avatar
Default squeek when turning on heat?
so recently ive heard a little squeek coming from my car, it is in the lower V-belt part for sure. Well coming home from work today i decide to turn on the heat, all the sudden this death of a squeal is coming out of my car. As soon as i turn the heat off it stops. can someone tell me what has happened and how to fix? pictures would be greatly appreciated.
Old Mar 14, 2009 | 07:51 AM
DaddySS's Avatar
If you have the defrost or bi-level on, the A/C compressor runs. Sounds like the belt to the compressor?
Old Mar 14, 2009 | 10:47 AM
yea thats what i was thinking, can the compressor go bad?
Old Mar 14, 2009 | 10:49 AM
Joshiedoom's Avatar
The compressor can go bad fast.. Mine is toasty and I have a video of it making a sound like a bent pushrod.
Most likely it is the idler and the tensioner/belt. Replace all three and you should be trouble free.
Old Mar 14, 2009 | 11:10 AM
is it the belt or the compressor? i just replaced my idler and tensioner pully
Old Mar 14, 2009 | 11:30 AM
Joshiedoom's Avatar
It could be both. Take the belt off and spin each of them. Replace with a new belt and listen. You can find used compressors on here cheap
