Help:water leak help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so its been raining here for several days off and on and i happened to find water in the rear seat area when i got off work. pics are attatched and thats after i dried alot of it up. i had 4 ponds 1 in each back seat part where your butt would sit and 1 in each floor board where your fit would be if your riding in the back seat.
anyone had this issue? what the hell could it be t-tops????
sorry the pics are dark it was dark and i only had a flashlight.
PLEASE HELP!!!
thanks, Hunter
the easiest way to figure out if it is, would be to run a garden hose (or take it to a car wash) over the top to see exactly where it is leaking. it's already wet inside so it's not gonna mess anything up that isn't fucked up already from the rain.
if you don't want to do it that way, you can get a can of compressed air and spray all along the weather strip from the inside and have someone on the outside of the car feeling for air leaking out, or vice versa.
have you had the stripping replaced recently?
i used the garden hose idea several times but no luck didnt have a chance to do the air idea yet. the weather stripping is what the car came with it just turned 68,000 miles yesterday but i always have put that stuff you can get at the parts house on it to keep it in good condition looks fine and is very soft with no cracks....
Water leaks suck because they are invisible. Everyone has good ideas, but in short, I would wait until it rains (or garden hoses), and sit in the car and feel and look around. Pulling the rear seats & the headliner will tell you A LOT!!
I have an '07 G6 GTP coupe that leaked like a colander and I had it to the dealership 3 times. They hire some ***-bag outsourced company that "fixes" leaks. When I finally looked into it myself, I found it was just a mis-manufactured moonroof drain tube and fixed it myself.
+1... if you park down hill.. its hard for water to travel out of the gutters in the hatch area and ultimately ends up in your back seat area.. i'm actually going to try this on my car.. as I have the same problem with my t top z car.
hope this helps
there is a picture below of what i saw there was wetness behind the drivers seat and where the backseats were but there was a puddle behind the passenger seat as seen in the picture
