Sponsored by: CARiD
torque fluctuating
Old Mar 30, 2009 | 05:31 AM
Camarobert's Avatar
Default torque fluctuating
I need help with my camaro z28 (year 2000).
The torque fluctuates when the car stands e.g. in front of a traffic light or in an drive in. then the automatic drive is in level "D" an i just hold my foot on the brake. after a few seconds it begins to fluctuate.
sometimes the engine brakes down...
it happens only with a warm motor...
has anyone an idea? thx a lot!
Old Mar 30, 2009 | 09:10 PM
NonGoggleGuy's Avatar
Does it sometimes stall when coming to a stop?
If so,
1. check your tranny fluid.
2. your torque converter could be failing. Next time it feels like it's gonna stall when stopping, downshift manually, 3-2-1, and if it stays running, your TC is the problem.
Old Mar 30, 2009 | 09:12 PM
Otherwise, check your fuel pressure, fuel filter, air filter, plugs, wires, cats.
Old Mar 30, 2009 | 09:35 PM
wssix99's Avatar
Save the manuals!
I assume your post means that you are getting a surge at a standstill? If you don't feel the surge when you are in Neutral, then its the torque converter.
Old Mar 31, 2009 | 05:14 PM
TAtoad's Avatar
my grand am does this, but i think its a dry cracked vacuum hose
Old Apr 13, 2009 | 04:01 AM
Camarobert's Avatar
The reason: wrong plugs (cheaper one)
The solution: new AC Delco 41-985 installed
