Sponsored by: CARiD
intake install
Old Apr 1, 2009 | 07:26 PM
slayerized6's Avatar
Default intake install
before i embark on installing my new intake, i have a few questions.
1. ls6 coolant lines- is it necessary I drain the coolant before i swap the coolant lines? i just changed the coolant last month and dont want to deal with that crap again. i do expect some coolant would leak out, but not a lot. correct me if im wrong
2. back of the the intake i got a map sensor, a big vacuum line that goes to the brake booster, and then a small vacuum line. where does that vacuum line go to (pcv system?)?
Old Apr 1, 2009 | 08:05 PM
NonGoggleGuy's Avatar
No need to drain coolant. If I remember correctly, that small vacuum goes to the AIR.... but I may be wrong.
Old Apr 1, 2009 | 08:17 PM
Gaunt's Avatar
If emissions aren't stringent where you live, now is the time to remove your AIR and EGR systems.
Old Apr 1, 2009 | 10:02 PM
just deleted both systems last week.
Old Apr 1, 2009 | 11:08 PM
Magic Man's Avatar
Don't delete the little vacum line as it runs a couple of things one of which is the dash vents.
Old Apr 1, 2009 | 11:09 PM
where does the other end of the vacuum line plug into?
Old Apr 2, 2009 | 12:00 AM
Magic Man's Avatar
It runs to a juction by the ecm and runs to a canister up by the radiator another line off it goes into cabin and I think there is a 3rd but right off hand don't remember but if you look it's a Mickey Mouse setup off the AC lines by the ecm.
