Sponsored by: CARiD
Coolant bolt problem?
Old Apr 11, 2009 | 06:48 PM
INTENESS's Avatar
Default Coolant bolt problem?
Here's my predictment that im in.Installing a aftermarket autometer electronic gauge on my car all wiring is good go to take the coolant bolt out on the passanger side head on the back,It is a tork socket to take it out but it is stripped out pretty bad any idea's on what i should do to get this bolt out will be helpful.
Old Apr 11, 2009 | 07:20 PM
Magic Man's Avatar
Take the starter out and see if you can use a chisel or screwdriver to tap it around and get it out or as some say get a nut welded to it an remove.
