Horn wiring
i am assuming that the spring part of the red wire goes in there since i put it there and horn went off.
car was attempted to be stolen at one point...not sure if it affects it at all.
The fix is to pull the steering wheel and replace the turn signal cam. (The socket is built in to this part.) You just need special tools to pull the wheel and undo the lock plates underneath. The cam itself is a couple of bucks at any autoparts store - usually in the Help! section.
