Sponsored by: CARiD
How do I fix wheel hop?
Old Apr 13, 2009 | 01:21 PM
photoman9988's Avatar
Default How do I fix wheel hop?
I tried the search, but the search here SUCKS. Anyways, I have a MAJOR problem with wheel hop and I floor it from a dead stop. It does it EVERY time. How do I fix it?
Old Apr 13, 2009 | 01:25 PM
spaz1's Avatar
Get some rear Lower control arms with poly bushings. I also added a set of lower control arm relocation brackets from Afterhtoughts auto. Worked mint. Control arms only would probably do the trick.
Old Apr 13, 2009 | 04:18 PM
NonGoggleGuy's Avatar
A stiffer or adjustable torque arm will eliminate wheel hop as well.
Old Apr 13, 2009 | 04:58 PM
wadelieck's Avatar
fixed my wheel hop
Old Apr 13, 2009 | 05:04 PM
therealcreeper's Avatar
x2 on the lca's and relocation brackets
although i have absolutely insane wheel hop in reverse now, not that it matters
Old Apr 13, 2009 | 10:33 PM
HWI's Avatar
HWI
I had wheel hop, added LCAs with relocation bracket and torque arm at the same time, solved my problem. If you are lowered, then I'd try the LCAs with relocation bracket first.
Old Apr 21, 2009 | 12:13 PM
spaz1's Avatar
https://ls1tech.com/forums/lsx-parts...ewood-lca.html
These will help a lot wit wheel hop.
Old Apr 21, 2009 | 09:03 PM
9t8z28's Avatar
This is the hardest question to answer. All of the remedies mentioned could possibly cure wheel hop. Honestly you will never know until you try.
IMO, this is your car so you know it best. Take a look at some of the bushings and there condition.
SHOCKS!! If you still have the stock deCarbons, chances are they are on there way out. If they are weak (actually they suck from day one) they will do nothing to control the rear.
Old Apr 24, 2009 | 06:57 PM
joblo1978's Avatar
Lower control arm relocation brackets eliminated mine. Beefier LCA's really stuck it to the ground. I have no hop at my power levels even while roasting the tires at speed, still on stock torque arm too.
Get LCA brackets and go from there.
Old Apr 24, 2009 | 07:36 PM
dragonrage's Avatar
Don't use poly-poly LCAs. There are other threads on this, but use either 1LE rubber or poly-rod or rubber-rod. Don't use rod-rod or poly-poly. (Rod-rod is actually good, but they wear too quick for a lot of people that use them on a DD)
Old Apr 24, 2009 | 08:12 PM
01ws666's Avatar
Are you saying not to use LCAs with poly bushings on both ends? If so can you explain why? I'd do a search but yea the search blows lately...
Old Apr 24, 2009 | 08:50 PM
dragonrage's Avatar
Go to the suspension section. Here's one of the bigger LCA threads there: https://ls1tech.com/forums/suspensio...trol-arms.html
