Sponsored by: CARiD
Blinker Trouble
Old Apr 19, 2009 | 05:41 PM
hunter_p1's Avatar
Default Blinker Trouble
I am having trouble with my right blinker. I get a constant green on the dash and the bulb is constantly lit up in the rear but nothing on the front. I replaced both bulbs. I tried the flashers and all but the front works fine. But when I turn on the headlights, the front bulb lights up fine with the exception of not blinking.
The bulb socket looks in perfect condition and the ground is in good shape next to the radiator support.
So. What is the next step? What am i missing?
Old Apr 19, 2009 | 05:45 PM
SparkyJJO's Avatar
http://kalecoauto.com/index.php?main...&products_id=6
When the headlights are off, is the running light on?
The front bulbs have 2 filaments, a bright and a dim. Dim is running light at night, Bright is blinker and daytime running lights. Sounds to me that the bright filament is not getting lit.
Old Apr 19, 2009 | 06:38 PM
hunter_p1's Avatar
I just checked and the bulb is not lighting at all when the other drl is on.
Old Apr 19, 2009 | 06:43 PM
im2fast4u98z28's Avatar
look at the socket and make sure none of the prongs are bent and try wiggling the wires and the bulb. if you haven't already, change the bulb first.
