Sponsored by: CARiD
alternator
Old Apr 21, 2009 | 06:54 PM
doomsdaymachine's Avatar
Default alternator
i have two questions
1.whats the proper way to remove an alternator from the car
2. can be fix, if already is losing charge and pulley makes noise?
thanx
Old Apr 22, 2009 | 12:28 PM
bump...
Old Apr 23, 2009 | 06:13 PM
Sykokilla's Avatar
BUMP
I'd also like to know how to remove it.
or a point to a guide.
thnx
Old Apr 24, 2009 | 12:39 PM
sman's Avatar
Take the tension off of the belt. Get the car in the air remove the 2 bolts that hold the alternator to the bracket, and remove the one bolt on the back of the alt holding it to the other bracket. Pull it down and forward and slide it out between the front sway bar and the rad fan assembly. Depending on the situation it could be easier to remove the alt bracket with it, its only 1 more bolt, located between the idler and the alt.
Chiltons says....
5.7L Engines
1.
Before servicing the vehicle, refer to the Precautions Section.
2.
Remove or disconnect the following:
Negative battery cable
Accessory drive belt
Alternator rear inner brace
Transmission oil cooler line clips
Alternator bolts
Alternator electrical connectors
Alternator
Exploded view of the alternator and related components—5.7L engine
Click to Enlarge
To install:
Install or connect the following:
Alternator
Alternator bolts. Torque the bolts to 37 ft. lbs. (50 Nm).
Alternator rear inner brace. Torque the nut to 18 ft. lbs. (25 Nm).
Alternator electrical connectors. Torque the battery cable nut to 16 ft. lbs. (22 Nm).
Old Apr 25, 2009 | 12:13 AM
BlackHawk256's Avatar
Just did this last week. First disconnect the negative battery cable, loosen the serpentine belt and jack the car up (Use manual jack stands to hold the car up, NEVER rely solely on a hydraulic jack),go under and there should be 2 15mm bolts in front and transmission cooling line clips in the way. There should be 1 13mm bolt in the back. Finally take the boot off and and unscrew the next bolt in the back which should be another 13mm. Getting the alternator out will require some maneuvering back and forth until you are able to find the right positon to slide it out. Unclip the alternator plug, and that was it for me. Install is the reverse process. It is best to have an assortment of tools for removal/installation.
If you are having problems finding an alternator, I read in Car Craft that some alternators off the 5.3L or other gm truck motors were identical.( Check to make sure which ones.) Well hope this helps you.
Old May 23, 2009 | 12:14 AM
Sykokilla's Avatar
thnx alot SMAN!
Im currently laughing over the mustang ads on this site.
chevy=team players
Old May 23, 2009 | 12:46 AM
LS1Silverado05's Avatar
Dont forget that one wire connector that comes from the top....its real easy to forget it while you are under the car and you will pull the wire right out of the plug real easy....ask me know I know...
