Sponsored by: CARiD
squeak/rattle brakes?
Old Apr 22, 2009 | 10:00 PM
iceman15's Avatar
Default squeak/rattle brakes?
When I was driving earlier today I was getting a squeak/rattle from what sounded like the brakes on the passenger rear. It only happened at low constant speeds and during slow turns. What you guys think it is?
Old Apr 22, 2009 | 10:31 PM
antsls1's Avatar
not an expert but it kind of sounds like either a warped rotor or a caliper piston sticking. i do know on the other hand that my car was doing something similar but only when and after i applied the brakes. but i no mine was due to a stickin caliper. i have heard that a shop can warp ur rotors by a high torque impact wrench. have u had a shop take ur wheels of lately and have done a brake job lately. cuz that is what happened to mine. a 60 dollar brake job has now turned into a 400 dollar brake job. i have replaced both front calipers, both caliper mounting brackets, both rotors and a two sets of good pads(glazed the first set). good luck!!!
Old Apr 22, 2009 | 10:57 PM
CaliforniaBoy5's Avatar
sure it isnt suspension related?
Old Apr 22, 2009 | 11:27 PM
iceman15's Avatar
I haven't taken it to any shop, I try and do all my work but i I haven't taken any wheels off in a while.
But I guess it might be the suspension needing tightening, I will definatly try that out. I thought I read somewhere about people having problems with a clip going bad in the calipers causing excessive play? Have you guys heard anything about that?
Old Apr 23, 2009 | 07:51 PM
antsls1's Avatar
i havent heard anything bout it but if its suspension i would start by checking sway bar bushings, then tie rod ends, then all ball joints.
Old Apr 24, 2009 | 10:26 AM
dragonrage's Avatar
Also make sure your brake pads are greased in the appropriate places.
