Sponsored by: CARiD
idle problem
Old May 4, 2009 | 10:04 PM
bobbyd's Avatar
Default idle problem
aight guys i have a small little problem with my car sometimes.
when my car is idleling and sometimes while is warming upsometimes the idle goes a little higher after a few minutes.
i have clean the filter,maf,tb and i have changed my pcv valve.
could it be my coolant that needs to be flush or what other things can i check?
Old May 4, 2009 | 10:47 PM
LS6427's Avatar
Coolant has nothing to do with idle quality.
First check for any codes with a scanner, whether you have an SES light or not.
A vacuum leak usually cuases the idles to be higher than normal. Also, a failing IAC (Idle air control) valve. Its on the TB and has an electrical plug. top left side of the tb.
Old May 4, 2009 | 10:52 PM
bobbyd's Avatar
ahhh i think its going to be the IAC since I use to get a code for that but I replaced it with one from a extra tb that I had.
