Sponsored by: CARiD
powerstering issues?
Old May 12, 2009 | 08:21 AM
NonGoggleGuy's Avatar
...and that new PS bracket you bought is the same size as the OEM?
Old May 12, 2009 | 03:35 PM
2002redhawk's Avatar
Yep. Im flustered. I dont know what it could be. Everythings on right. The only thing i can think of is the pulley isn't pushed onto the pump enough? It looks like its lined up tho. I really dont know what to say. Its def. coming frmo the power steering pump. Its Squeaking sound Just like a bad belt or something. Its really loud. And Gets worse when you give it gas. Powersteering on the other hand works fine and all the airs out of the system.
Old May 12, 2009 | 07:32 PM
So i was wrong. The noise is actually coming from the big black round *thing* thats right below the air intake tubing. Thats where the squeaking is coming from. I guess this means i need a new one?
Old May 12, 2009 | 07:37 PM
Wesmanw02's Avatar
Waterpump.
Sounds like the bearing is shot.
You can get a GM one for around $130, PM me if you want a link. Very easy to replace.
Old May 12, 2009 | 07:46 PM
MAN! i just had this replaced! this is stupid
Old May 12, 2009 | 07:54 PM
is the waterpump/pulley 2 different pieces or one?
Old May 12, 2009 | 08:49 PM
Wesmanw02's Avatar
All one unit. You can't just change the shaft/bearings.
Old May 12, 2009 | 08:59 PM
wierd thing is that it doesnt make the noise with the belt off. If you hand turn it, it doesnt make any sounds. Its quite wierd. .
Old May 12, 2009 | 09:02 PM
Wesmanw02's Avatar
Thats because there is no stress on the bearing. With the belt on, it has tension, which causes the bearing to squeal while its spinning.
Old May 12, 2009 | 09:08 PM
Well, at least you finally know what it is.
