Sponsored by: CARiD
ABS inop light is on???
Old May 13, 2009 | 12:46 PM
TRUCKIN's Avatar
Default ABS inop light is on???
What the hell is that? I know it has something to do with my breaks. I did an engine swap and after the swap was done this light was on. Any ideas???
Old May 13, 2009 | 01:07 PM
1redta's Avatar
check all your brake lights to include the high mount, first. then check all your abs connecters on the wheel, and check your rear end. 3ch abs is on the center section and I guess 4ch abs is on the outside of the axles. When I swapped out my motor, I pinched the abs wire running down the engine compartment on the driver side. It on the frame in a metal heat shield under the brake master cylinder and had the abs light on, I soldered it together and evrything as been good since then
Old May 13, 2009 | 08:53 PM
TRUCKIN's Avatar
Thanks I will check that out.
