Sponsored by: CARiD
Turn signals are really slow!
Old May 16, 2009 | 10:53 PM
Tom565's Avatar
Default Turn signals are really slow!
I had an 2001 V6 Firebird and the turn signals on it were quite fast. I just bought a WS6 and the turn signals are really slow. After I push the arm up or down, the arrow comes on but it takes a good second or so for them to start flashing and it’s still slow. Water does get in the front housings and I have already replaced both front bulbs but I don’t know if this has anything to do with it or not.
I did a search and came up with nothing. And no, I don’t need to change my turn signal fluid so don’t even suggest that crap. lol.
Old May 16, 2009 | 11:44 PM
slayerized6's Avatar
check the sockets for corrosion. could also be the flasher unit
Old May 17, 2009 | 07:02 AM
wssix99's Avatar
Save the manuals!
If your bulbs are all good, then you just need a new flasher.
Old May 17, 2009 | 08:03 PM
peterlawl84's Avatar
Sounds like the flasher unit. I had the same problem, then the lights finally stopped blinking all together. I picked up one at autozone for like 10-20 bucks.
Old May 17, 2009 | 09:49 PM
Tom565's Avatar
thanks guys, I will check the flasher
Old May 18, 2009 | 08:07 AM
slvr98camaro's Avatar
has the same problem, but only on the left side, took the bulbs out, cleaned the connectors up a bit, and its been fine ever since
