Sponsored by: CARiD
throwing code for high idle, 1600rpm in neutral?
Old May 21, 2009 | 10:38 PM
therealcreeper's Avatar
Default throwing code for high idle, 1600rpm in neutral?
so yesterday i got an SES light for high idle rpm. i have been noticing my car shifting a little funny and holding out on shifts but not really idle problems.
anyway, today i was cruising at about 60mph and noticed that when i let off the gas the rpm would not drop at all, felt almost like cruise control was on. just to see what would happen i dropped it to neutral and it wouldn't drop below 1600rpm. later on, going 35ish i dropped to neutral and it revved up to 1600, held, then dropped down after a few seconds.
i've never really payed attention to idle in neutral at high speeds, but it seems a little off. something just doesn't feel right about the throttle but i don't quite know how to describe it.
Old May 21, 2009 | 11:05 PM
LS6427's Avatar
Check for vacuum leaks.
Also, failing IAC valve can do that.
Old May 22, 2009 | 12:50 AM
slayerized6's Avatar
vaccuum leak. did you pull the code with a scanner?
