Sponsored by: CARiD
Headlight Issue
Old May 22, 2009 | 10:00 PM
Happytokr's Avatar
Default Headlight Issue
I have read evey thread on here about the headlights. I think I am having an issue with the headlight control moduel but you guys know best.
Just replaced the headlight motor for the 9th time in less than a year. The headlight motor will not do anything at all like no power. The connector was corroded but I have cleaned it now I have no power to the right headlight motor. The lights work fine, can manually lift the motor, checked all fuses and wires to make sure there is power and not getting power down the line. But my main question is....Where is the headlight control module on the car?
Please help me gods of ls1tech.
2001 Pontiac TA WS6 5.7
Last edited by Happytokr; May 22, 2009 at 10:55 PM. Reason: Forgot car information!
Old May 27, 2009 | 01:44 PM
Happytokr's Avatar
Just FYI for anyone who looks at this. The headlight control module is on the driver side attached to the front fuse box. It is flat and on the side. I have fixed my issue had to run new power lines from the headlight control module to the headlight motor. Works like a champ.
Old May 28, 2009 | 03:14 PM
C6 Corvette Z06's Avatar
Default I have headlights that make a terrible noise when I lock the car
My headlights flip up and go down, (no lights on) anytime the lock button is pressed. Then it make a terrible sound like the motor is still pushing them down beyond the stop. A growl like sound. It happens every time.
I think it started when a body shop fixed the hail dents and did not adjust the headllight cover correctly. You can see where it was hanging-as it rubbed off the paint where it contacted the hood.
Two dealers said, you need new headlight motors. They are about $800 each! Another person told me, no you don't need a new motor, it is an adjustment issue. I could not figure out what he was telling me. I tried, but I am not very patient. My brothers, who build old Corvettes and even airplanes kid me saying, "You have the patience to peel an orange and that is about it". They are right!
Anyone know what to do.
By the way, I stopped locking the car for about a week. Then it was OK and everything worked OK, until one day, I hit the lock button twice. It started this all over again and now will not quit.
Of course the body shop guy denies any responsibility even though you can see where the paint is scrapped off.
JC
Old May 28, 2009 | 08:55 PM
ImTheCeo's Avatar
https://ls1tech.com/forums/pontiac-f...eadlights.html
this should help you out
