Coolant Capacity?
I just replaced my radiator and I flushed it out but left the new water in it, and it only took about 1 gallon after taking the old one out and putting the new one it.
I just ran the car with the heater on and the cap off so the air could get out, then filled it up as the level went down.
Here's how you flush every drop out.
Best/easiest way to flush and get every drop of old coolant out.
Cold engine.
Remove radiator fill cap.
Remove the t-stat. (2-3 minute job)
Put t-stat housing back on. (1 minute)
Take the entire radiator drain valve (petcock) "off", don't just open it. It'll drain faster with it off and thats what you want. ((Buy a new petcock, sometimes they break when you remove them all the way, they're like $2.00))
Take a hose and stick it in the radiator fill cap, running medium to high.
Start the engine.
Let it run for about 15-20 minutes or until the water is running out the drain CLEAR.
When it does your entire system is clean. 100%.
Put the t-stat back in.
Put the drain valve back in. Use the new one, what the hell.
Put half a jug of Dexcool in the radiator. (Or if you live in very cold places, 1 ½ jugs of Dexcool)
Fill the rest with water. (one bottle of water wetter can't hurt, your choice)
**Let it run and warm up till the t-stat opens once and starts to flow, to see if the level drops, just to make sure the system is completely full of coolant, if it drops just top it off. Then wait one more time for the t-stat to open and start to flow, then top it off again.**
Done.
