Sponsored by: CARiD
squeaking?
Old Jun 3, 2009 | 10:31 PM
poopshootSS's Avatar
Default squeaking?
my rear end on my 01 SS squeaks,someone told me that its my lower control arms. could it?
Old Jun 3, 2009 | 10:37 PM
Jersey Mike's Avatar
I'm trying to find out what mine is.
Mine just started a couple days ago.... only happens under very light throttle. It's a squeaking/rattling sound. Sounds like it's coming from the rear passenger side.
Who was the "someone" that told you it was your LCA?
Old Jun 3, 2009 | 10:55 PM
a buddy whos a tech,but idk it only sounds like that over speedbumps and dips.
Old Jun 21, 2009 | 07:02 PM
00TAM6's Avatar
i got the same exact problem but mine sounds like its coming from the rear driver side..
Old Jun 21, 2009 | 08:04 PM
ULTIMATEORANGESS's Avatar
i had my exhaust bushings replaced and my rear squeaks went away.
Old Jun 21, 2009 | 08:27 PM
dabest09's Avatar
my rear passenger side makes a clicking noise when i make a sharp turn. anyone know what it could be? the antenna is nice and tight. cant figure it out
Old Jun 21, 2009 | 09:12 PM
ItsNotStock's Avatar
Whenever this topic comes up on this forum (quite often) it's usually loose lca bolts, or a squeaky rear spring isolator...
Old Jun 21, 2009 | 10:42 PM
dabest09's Avatar
idk what lca bolts are. sorry lol
Old Jun 21, 2009 | 11:01 PM
twelver12's Avatar
im goin with muffler bearings on this one for sure.
are these stock or aftermarket lca's my umi lca's squeaked a bit at first but it went away
and DABEST09 your clicking is your axle bearings your antenna would never make that kind of noise, im assuming you dont know what those are either if you dont know what lca's are so take it to your local dealership and tell them and they will fix it for you
Old Jun 21, 2009 | 11:18 PM
dabest09's Avatar
so you're saying you know what my antenna sounds like when it is loose? and you know exactly what noise i'm talking about? all i said was that it clicks. it could be a hundred different things
Old Jun 21, 2009 | 11:26 PM
twelver12's Avatar
no if it clicks when your turning its the axle bearings thats the only thing back there that would do that
Old Jun 21, 2009 | 11:52 PM
jordan 98 z28's Avatar
My stock LCA's squeaked like hell. When I replaced them with the UMI LCA's squeaks went away.
Old Jun 21, 2009 | 11:54 PM
Mean87SS's Avatar
The Lower control arm... bolts that hold them to the brackets/to the rear
Old Jun 22, 2009 | 11:55 AM
dabest09's Avatar
thank you
Old Jun 23, 2009 | 02:42 AM
Radcannon's Avatar
I agree with twevler. If its clicking on turns it axle.
As for your signature twelver. Hahaha sweet. 14.7 psi huh thats pretty accurate boost measurement. Thats absolute right ? haha
Lca's will make nosies but if its tight its tight and fine who cares throw so lube on there and its fine. If you can hear that in the first place you have bigger issues. LIke why in the hell is ur exhaust so quiet.
Old Jun 24, 2009 | 01:04 AM
twelver12's Avatar
yes 14.7 is atmospheric pressure it throws all kinds of ppl off when you tell em your runnin 14 pounds everybody is so obsessed with turbos now a days they start askin about your turbo right away after that, i get ppl on it all the time
Old Jun 24, 2009 | 10:39 PM
BradsLS1's Avatar
I have the same problem but it is the rubber shock bushing. It took me forever to figure it out. The rubber bushing squeaks like crazy. I put WD on it then it goes away for a while and then comes back. Go to whatever side is doing it. Push up and down on that side and listen if it does it then get under it and pull and push to get it moving you should be able to pin point it from there.
