Help, major smog problems!!!
HC(PPM)
15mph MAX = 54 Meas=835
25mph MAX = 37 Meas=848
CO(%)
15mph MAX= .51 Meas=6.51
25mph MAX= 5.34 Meas=5.34
NO(PPM)
passed Max was 420, mine was 220
what the hell is going on here?
CO-Carbon Monoxide is what is removed by a catalytic converter. The CO passes over Alluminum Oxide that when heated releases an extra Oxygen molecule to change the CO to CO2-Carbon Dioxide. Do you have cats? Are they bad?
A lot of times a bad cat that is not clogged will glow red with heat when you drive around. Next time you park hop right out and smell for a burning/ hot smell and look at the cats.
We just fixed this on my dad's show truck and it improved both his CO and HC readings.
HC(PPM)
CO(%)
NO(PPM)
