Sponsored by: CARiD
Bad coolant temp sensor or ground? Help asap
Old Mar 22, 2018 | 09:52 PM
Dylanlars's Avatar
Okay guys I replaced the coolant temp sensor and the pig tail but still getting a check gauges light and the water temp was pegged. How Can I test if the sensor is getting a good connection? Is it just a bad sensor?
Old Mar 22, 2018 | 10:42 PM
Dylanlars's Avatar
Is it possible to just use the same ground as the coil packs instead of running a whole new wire to the back of the engine?
Old Mar 23, 2018 | 12:14 AM
peterpar's Avatar
The 1998 temp sensor has two different thermistors that control the dash gage and the PCM using separate circuits. The dark green wire goes to the gage and the ground path is through the thermistor from the sensor base being screwed into the head. If you grounded the dark green wire, in effect you would be by-passing the sensor and the gage would read hot all the time. If the yellow wire going to the PCM is grounded, it would essentially be the same situation, only the PCM functions would be affected. You need to trace out the circuits to make sure no wire has grounded out.
Old Apr 7, 2018 | 09:52 AM
Dylanlars's Avatar
I’ve rewired the pigtail and soldered my wires. The gauge reads fun now but once the car reaches 210 degrees and the fans kick on the idle shoots up to 2k then drops to 800. SES light still says it’s the coolant temp sensor. Any guesses?
Old May 1, 2018 | 11:34 AM
OutlawZ28LS1's Avatar
Did you ever figure this out? dealing with a similar situation with my 98 z28. replaced sensor, acted fine for a day then the gauge started pegging making it unable to start with a warm engine unless gas pedal was mashed to the ground, killing the injectors. Does your car have a hard time starting with a warm engine when your gauge starts acting up?
Old May 1, 2018 | 01:48 PM
Dylanlars's Avatar
yes the car went into a safe mode. I re-wired a new pigtail and a new do sensor now the gauge works fine. My car still idle surged from 800 to 2000 so I took it to a shop and now they are saying the cause of the idle or the bad sensor is from the resistance of my new msd wires. The whole problem started after I did plugs and wires
Old Dec 23, 2019 | 03:11 PM
LooseBruce's Avatar
I have a 2001 3.8 bird and after about 6o miles or so, my gauge would drop to zero and the cooling fan come on for no reason. If I reset the codes, everything is fine. No idle/rpm surge at all. Suggestions on this?
