Sponsored by: CARiD
Oil problem?
Old Jun 25, 2009 | 10:48 PM
GOR1LA's Avatar
Default Oil problem?
I drove my car a couple days ago and everything was great. Good pressure ran good. My low oil light was on but i have bad sensor. So thought nothing of it drove 50 miles or so. Came on and parked it. I thought i better check it cause i wanted to drive it tomorrow. While i checked it and its all the way down to the add line.
Oil smells good dirty but i changed to pennzoil so not worried there.
What could be the problem? Should i just change my oil tomorrow and drive her a bit and see if im losing oil?
This is the first time it has done this and been so low...I alittle worried.
Old Jun 25, 2009 | 11:08 PM
LS6427's Avatar
The add line is only like a quart low. How long has it been since you filled it with 5 1/2 quarts?
Old Jun 25, 2009 | 11:28 PM
GOR1LA's Avatar
1500 - 2000 miles...i check it every 2 weeks or so. Was fine about a 2 weeks ago.
Old Jun 26, 2009 | 05:24 PM
GOR1LA's Avatar
Hey guys i put a quart of oil in and took it for a drive...when i got home i heard a tick noise...so i poped the hood and my number 8 ignition coil was arcing and making the noise...what could have caused this and what should i do?
Old Jun 26, 2009 | 06:13 PM
LS6427's Avatar
Usually if they crack they will arc. You need to replace it.
Maybe just a coincidence with the oil issue.
