Sponsored by: CARiD
Any ideas on what this could be?
Old Jul 1, 2009 | 05:59 PM
SheffyZ28's Avatar
Default Any ideas on what this could be?
ok my car has 133k miles on it, and it started a ticking sound, though it was possibly a collapsed lifter, its been doing it for about 3 weeks or so now, but today i was leaving my friends house about a mile away and it started shaking the ses light was flashing at me and it was idling rough as I was pulling up to the stop sign and i could feel it trying to die on me on my street and i got it into my garage and turned it off, turned it back on and now its shooting out blue and white smoke, and now the ticking is gone. so anyone have any ideas?
Old Jul 1, 2009 | 06:05 PM
LS6427's Avatar
Flashing SES means cylinder misfires. Blue/white smoke is oil.
Is it smoking at idle, under acceleration or when you take your foot off the gas pedal?
Old Jul 1, 2009 | 06:37 PM
SheffyZ28's Avatar
it smokes when i rev it
Old Jul 1, 2009 | 07:24 PM
LS6427's Avatar
May have a bad ring issue. I'd get a compression check done. See if you can get a scan to which cylinder it is.
If you take your oil fill cap off while its idling, then you rev it a little bit, do you get little puffs of air coming out?
Old Jul 1, 2009 | 08:05 PM
SheffyZ28's Avatar
i havent tried it yet
Old Jul 2, 2009 | 03:31 PM
ILLWS6's Avatar
Just a guess, maybe the ticking was a plug wire arcing and now the wire went dead completely, causing the misfire. Maybe the smoke is a result of that cylinder not firing.
Another Idea is maybe the ticking was a lifter or rocker arm going out and it finally went completely. Check your plugs, wires, pull the valve covers and check for damage.
Old Jul 5, 2009 | 01:24 PM
SheffyZ28's Avatar
we actually tried that, everything looked fine, then a couple days later it all went, so i ordered a new block with rolling assembly so im just going to go that route since the mileage on it already, and the trans had been rebuild about a year ago
