Sponsored by: CARiD
crank sensor
Old Jul 5, 2009 | 08:05 PM
romeric's Avatar
Question crank sensor
whats up everyone? i need to change my crank sensor (CKP).need to know where is located and how to replace it. thanks in advance
Old Jul 5, 2009 | 09:06 PM
LS6427's Avatar
drop the starter and you'll see it. It comes out easy, you'll see how when you look at it.
Old Jul 6, 2009 | 05:28 AM
irocbmx's Avatar
romeric, what was the symptoms of your car before you knew you had to rplace the crank sensor? I have been having some stalling issues with my car, and i think it could be the crank sensor but its not throwing any codes.
Old Jul 6, 2009 | 01:12 PM
LS6427's Avatar
Random stalling, hard starts, then it runs fine, then it runs bad again, then it won't start, etc.... are the main symptoms of a "FAILING" crankshaft position sensor. Not saying thats 100% your issue though.
You will NOT get an SES light until it fails completely. When mine failed 2 years after I bought my car thats what I went through. After about 2 days of that crap I had it towed to the dealership and they changed that sensor and it was fine.
Old Jul 6, 2009 | 01:31 PM
2001NBMZ28's Avatar
OP - If you replace the sensor believe you need software to do a CKP relearn procedure.
Old Jul 6, 2009 | 11:41 PM
romeric's Avatar
i was having some hard starts. and also gave me the code. thats how i noticed it.
