Sponsored by: CARiD
Low Oil Light
Old Jul 14, 2009 | 03:16 PM
GreenBlood's Avatar
Default Low Oil Light
My low oil light came on for the first time ever. I checked it, and it was super low. My car has no leaks on the driveway at all. Pressure is still like it always is. around 25-30 @ idle, 40-45psi @ 1k-1.5k rpms, and over 55psi @ WOT. I added two quarts of oil, drove around, checked the level, and its fine, but the light won't go off. Could something else be wrong?
Old Jul 14, 2009 | 03:27 PM
Jassick's Avatar
only thing I can guess is you were really low and those 2 quarts weren't enough to fill it past the low oil like trip. Course if it just came on that doesn't make any sense either.
As far as it being low to begin with, I think that's a pretty common issue on these cars. I know mine will take an extra quart or so between oil changes.
Old Jul 14, 2009 | 03:42 PM
2001NBMZ28's Avatar
Give it a few ignition cycles, the low oil light doesn't reset until the PCM sees 194* ECT, then goes off on the next cycle.
Old Jul 14, 2009 | 06:59 PM
GreenBlood's Avatar
ok thanks.
Old Jul 15, 2009 | 01:34 AM
GreenBlood's Avatar
it reset itself. thank god it was nothing else
