how do i replace the turn signal switch??
John
1. Remove air bag fuse and disconnect air bag connector at base of column (yellow harness and connectors)
2. Remove air bag, steering wheel and clock spring. The clock spring is held in with a snap ring, so you will need snap ring pliers.
3. As you pull the clock spring off the steering shaft, hold it firmly in your hand, being carefull not to turn it. Put a ziptie through the middle and tighten it down to lock the center and outer portions in place. ROTATING OF THE CLOCKSPRING WILL CAUSE DAMAGE AND WILL CAUSE AIRBAG AND STEERING WHEEL RADIO CONTROLS TO BE INOP.
4. Pull clockspring harness up far enough to get to the lock plate.
5. Using a lockplate tool, compress the lockplate and remove the lock ring from steering shaft. Two picks or small screw drivers are usually the best tools to use to remove the lock ring. Remove lock plate.
6. With lock plate removed, pull clock spring harness up through column. It may help to tie some string or wire to the end of the clock spring connector, so you can fish it through the column to get it back in.
7. Remove the horn contact hub (white piece with a steel contact on it) and the spring below it. At this time you should be able to see the turn signal switch.
8. Remove the turn signal stalk by pulling straight out firmly. You will swear you are going to break it but you won't. Do not pull it out too far or you may break the tiny wires that make up the cruise control harness if so equipped.
9.Remove the three screws in the turnsignal switch and the one screw that holds the hazard **** on.
10. Pull the turnsignal switch up over the steering shaft and pull the harness through using string or wire again to be able to fish the new wiring through.
11. Reverse procedure to install.
You may want to contact your local GM dealer and see if they can print out a copy of the breakdown of your column. This will help with parts locations and orientation.
Good Luck!
Good Luck!
