Sponsored by: CARiD
how to adjust throttle?
Old Jul 20, 2009 | 02:22 PM
NeedaV8foundation's Avatar
Default how to adjust throttle?
my car was recently cammed and i noticed when i try to punch it im only getting about 3/4 throttle and the peddle is all the way to the floor, is there a way to adjust the cable?
car and mods are in sig, it does have tcs.
Old Jul 20, 2009 | 02:56 PM
PAGregSS's Avatar
On the throttle cable between the firewall and the TB, there is a round looking barrel with two halves that clip together. You want to unclip them and pull them apart until you can see the tb blade begin to open. Then, clip the two halves back together.
Old Jul 20, 2009 | 04:21 PM
LS1Fury!'s Avatar
Correct but you have it backwards. You push them together if you want the cable to be tighter and you pull them apart if you need more slack.
