Sponsored by: CARiD
Passenger side header gasket, question inside!
Old Jul 24, 2009 | 04:16 PM
01SOMZ28's Avatar
Default Passenger side header gasket, question inside!
So the passenger side header gasket looks a bit harder to change then the driver side. I'm just curious if i'll have to get the far back header bolt from the bottom or is there some way i can get it from the top?
Old Jul 24, 2009 | 04:54 PM
LS1Fury!'s Avatar
It's easier from the bottom.
FYI, spend the extra 10 minutes removing the coil brackets to get more room and to save your hands from getting beat up.
Old Jul 24, 2009 | 05:27 PM
01SOMZ28's Avatar
yea thats what i was planning on doing and maybe i can get it from the top, if not then i'll go from the bottom.
Old Jul 24, 2009 | 09:32 PM
RA032926's Avatar
i got mine from the top just fine with a stubby ratchet wrench
Old Jul 25, 2009 | 10:34 PM
LS1Fury!'s Avatar
If you have a stubby or wobble, it can be done from the top. Either way I still think its easiest from the bottom.
Old Jul 25, 2009 | 11:18 PM
loyolacub68's Avatar
You can do it from the top but I think its WAY easier from the bottom.
