problems after intake and LT install so i just recently installed some pacesetter LT's along with some msd wires and new ngk plugs also put a ls6 intake on. now the car seems to have a random misfire. cant figure it out i dont think its a plug wire because its not a consistant miss in the same cylender seems to be missing in random cylenders. could this be a intake leak? mabe a problem with the injectors? seems to get worse the more i drive it and when it warms up??? |
Most likely you have some sprak plug wires "touching" your exhaust manifold pipes. Very common after a LT install. If they're touching at all, they will arc, mainly in the mid-high rpms, but also at idle and low rpm. If not, just make sure both ends of all the wires are "snapped" into place. . |
thanks for the help ill have to check it out tomarro and let you know how it goes |
© 2024 MH Sub I, LLC dba Internet Brands
